Climate_ir_lg for LG S09EQR AC (Remote: AKB74955603)
Just wanted to share my excitement — I finally got the climate_ir_lg platform working with my LG S09EQR air conditioner!
Even better — it now receives signals from the original LG remote via an ESP32 module.
However, this required manually adjusting the timing parameters, since the duration of the first pulse and pause are very different from what the plugin originally expects.
Here’s my working .yaml config:
esphome:
  friendly_name: ESP32 LG IR
esp32:
  board: esp32dev
  framework:
    type: arduino
wifi:
  ssid: "ssid_name"
  password: "your_password"
  manual_ip:
    static_ip: x.x.x.x
    gateway: x.x.x.x
    subnet: 255.255.255.0
  ap:
    ssid: "ESP32_Fallback"
    password: "87654321"
captive_portal:
ota:
  platform: esphome
  password: ""
api:
  encryption:
    key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
logger:
  level: DEBUG
external_components:
  - source: custom_components
remote_transmitter:
  pin: GPIO14
  carrier_duty_percent: 50%
remote_receiver:
  pin:
    number: GPIO33
    mode: INPUT
    inverted: true
  dump: all
  buffer_size: 2kb
  idle: 25ms
  tolerance: 50%
climate:
  - platform: climate_ir_lg
    header_high: 3100us   # LG remote pulse (in microseconds)
    header_low: 9900us    # LG remote pause
    bit_high: 470us       # Bit high duration
    bit_one_low: 1620us   # Bit 1 low duration
    bit_zero_low: 570us
    name: "LG Air Conditioner"
    transmitter_id: ir_sender
    receiver_id: ir_receiver
    visual:
      min_temperature: 18
      max_temperature: 30
      temperature_step: 1
Hope this helps someone who’s struggling with a similar issue.
The key was adjusting the header_high and header_low values to match the real-world remote behavior.
Today I ran into a problem while working with my ESPHome IR setup.
If the IR receiver is not optically isolated from the IR transmitter, and I send a command (for example, a swing flap command) from ESP to my LG AC, the command is executed by the air conditioner correctly, but Home Assistant interface behaves oddly:
  • The UI reacts to the command,
  • But then quickly reverts back to the previous state.
If I physically block the IR receiver from seeing the transmitter (e.g. by shielding or isolating them), everything works perfectly: Home Assistant receives the correct state update and displays it correctly.
So the issue seems to be caused by the receiver picking up its own transmitted IR signal. The received signal confuses the state machine, and the UI rolls back the state.
Is there a way to programmatically disable IR receiving while ESPHome is transmitting the IR signal?
For example: disable remote_receiver before transmission and enable it right after.
For this air conditioner model, I had to modify climate_ir_lg.cpp.
I added a block in the code to ignore any actions for LG remote control commands from the button that controls the air conditioner’s shutter.
Otherwise, these commands are processed incorrectly and cause the Home Assistant interface to set the temperature to 15-16 degrees °C.
bool LgIrClimate::on_receive(remote_base::RemoteReceiveData data) {
  uint8_t nbits = 0;
  uint32_t remote_state = 0;
  if (!data.expect_item(this->header_high_, this->header_low_))
    return false;
  for (nbits = 0; nbits < 32; nbits++) {
    if (data.expect_item(this->bit_high_, this->bit_one_low_)) {
      remote_state = (remote_state << 1) | 1;
    } else if (data.expect_item(this->bit_high_, this->bit_zero_low_)) {
      remote_state = (remote_state << 1) | 0;
    } else if (nbits == BITS) {
      break;
    } else {
      return false;
  ESP_LOGD(TAG, "Decoded 0x%02" PRIX32, remote_state);
  if ((remote_state & 0xFF00000) != 0x8800000)
    return false;
  // Adding a check for commands 0x13000 and 0x13100 — these are incorrectly handled shutter control commands
  uint32_t command = remote_state & COMMAND_MASK;
  if (command == 0x13000 || command == 0x13100) {
    ESP_LOGD(TAG, "Received ignored command 0x%02" PRIX32, command);
    return false;  // Just stop processing, do nothing
Damper Control Commands:
1000100000010011000101011010
0x881315A
1000100000010011000001001000
0x8813048
1000100000010011000001011001
0x8813059
1000100000010011000001101010
0x881306A
1000100000010011000001111011
0x881307B
1000100000010011000010001100
0x881308C
1000100000010011000010011101
0x881309D
1000100000010011000101001001
0x8813149
On this specific LG remote, the swing function shares the same button with the louver position selection. After cycling through all fixed louver positions, the button switches the unit to swing mode. This behavior sends the same IR command every time the swing function is toggled.
In my case, it was necessary to add command == 0x10000 to the list of ignored commands in the following block:
if (command == 0x13000 || command == 0x13100 || command == 0x10000) {
    return false;  // Skip processing
Without ignoring this command, the IR receiver would capture it and immediately revert the Home Assistant UI state back to the previous one, creating inconsistency between the physical unit and the HA interface.
Since the swing mode on this remote is tied to the same button as the louver position, there is no real need to track this command separately. If anyone needs to implement manual louver position control in the Home Assistant UI, it can easily be done via .yaml configuration.
Here is the modified climate_ir_lg.cpp file for the LG S09EQR air conditioner:
#include "climate_ir_lg.h"
#include "esphome/core/log.h"
namespace esphome {
namespace climate_ir_lg {
static const char *const TAG = "climate.climate_ir_lg";
// Commands
const uint32_t COMMAND_MASK = 0xFF000;
const uint32_t COMMAND_OFF = 0xC0000;
const uint32_t COMMAND_SWING = 0x13000;
const uint32_t COMMAND_ON_COOL = 0x00000;
const uint32_t COMMAND_ON_DRY = 0x01000;
const uint32_t COMMAND_ON_FAN_ONLY = 0x02000;
const uint32_t COMMAND_ON_AI = 0x03000;
const uint32_t COMMAND_ON_HEAT = 0x04000;
const uint32_t COMMAND_COOL = 0x08000;
const uint32_t COMMAND_DRY = 0x09000;
const uint32_t COMMAND_FAN_ONLY = 0x0A000;
const uint32_t COMMAND_AI = 0x0B000;
const uint32_t COMMAND_HEAT = 0x0C000;
// Fan speed
const uint32_t FAN_MASK = 0xF0;
const uint32_t FAN_AUTO = 0x50;
const uint32_t FAN_MIN = 0x00;
const uint32_t FAN_MED = 0x20;
const uint32_t FAN_MAX = 0x40;
// Temperature
const uint8_t TEMP_RANGE = TEMP_MAX - TEMP_MIN + 1;
const uint32_t TEMP_MASK = 0xF00;
const uint32_t TEMP_SHIFT = 8;
const uint16_t BITS = 28;
void LgIrClimate::transmit_state() {
  uint32_t remote_state = 0x8800000;
  // ESP_LOGD(TAG, "climate_lg_ir mode_before_ code: 0x%02X", modeBefore_);
  // Set command
  if (this->send_swing_cmd_) {
    this->send_swing_cmd_ = false;
    remote_state |= COMMAND_SWING;
  } else {
    bool climate_is_off = (this->mode_before_ == climate::CLIMATE_MODE_OFF);
    switch (this->mode) {
      case climate::CLIMATE_MODE_COOL:
        remote_state |= climate_is_off ? COMMAND_ON_COOL : COMMAND_COOL;
        break;
      case climate::CLIMATE_MODE_DRY:
        remote_state |= climate_is_off ? COMMAND_ON_DRY : COMMAND_DRY;
        break;
      case climate::CLIMATE_MODE_FAN_ONLY:
        remote_state |= climate_is_off ? COMMAND_ON_FAN_ONLY : COMMAND_FAN_ONLY;
        break;
      case climate::CLIMATE_MODE_HEAT_COOL:
        remote_state |= climate_is_off ? COMMAND_ON_AI : COMMAND_AI;
        break;
      case climate::CLIMATE_MODE_HEAT:
        remote_state |= climate_is_off ? COMMAND_ON_HEAT : COMMAND_HEAT;
        break;
      case climate::CLIMATE_MODE_OFF:
      default:
        remote_state |= COMMAND_OFF;
        break;
  this->mode_before_ = this->mode;
  ESP_LOGD(TAG, "climate_lg_ir mode code: 0x%02X", this->mode);
  // Set fan speed
  if (this->mode == climate::CLIMATE_MODE_OFF) {
    remote_state |= FAN_AUTO;
  } else {
    switch (this->fan_mode.value()) {
      case climate::CLIMATE_FAN_HIGH:
        remote_state |= FAN_MAX;
        break;
      case climate::CLIMATE_FAN_MEDIUM:
        remote_state |= FAN_MED;
        break;
      case climate::CLIMATE_FAN_LOW:
        remote_state |= FAN_MIN;
        break;
      case climate::CLIMATE_FAN_AUTO:
      default:
        break;
  // Set temperature
  if (this->mode == climate::CLIMATE_MODE_COOL || this->mode == climate::CLIMATE_MODE_HEAT || this->mode == climate::CLIMATE_MODE_HEAT_COOL) {
    auto temp = (uint8_t) roundf(clamp<float>(this->target_temperature, TEMP_MIN, TEMP_MAX));
    remote_state |= ((temp - 15) << TEMP_SHIFT);
  this->transmit_(remote_state);
  this->publish_state();
  uint8_t nbits = 0;
    return false;
      break;
    } else {
      return false;
    return false;
  // Get command
  if ((remote_state & COMMAND_MASK) == COMMAND_OFF) {
    this->mode = climate::CLIMATE_MODE_OFF;
  } else if ((remote_state & COMMAND_MASK) == COMMAND_SWING) {
    this->swing_mode =
        this->swing_mode == climate::CLIMATE_SWING_OFF ? climate::CLIMATE_SWING_VERTICAL : climate::CLIMATE_SWING_OFF;
  } else {
    switch (remote_state & COMMAND_MASK) {
      case COMMAND_DRY:
      case COMMAND_ON_DRY:
        this->mode = climate::CLIMATE_MODE_DRY;
        break;
      case COMMAND_FAN_ONLY:
      case COMMAND_ON_FAN_ONLY:
        this->mode = climate::CLIMATE_MODE_FAN_ONLY;
        break;
      case COMMAND_AI:
      case COMMAND_ON_AI:
        this->mode = climate::CLIMATE_MODE_HEAT_COOL;
        break;
      case COMMAND_HEAT:
      case COMMAND_ON_HEAT:
        this->mode = climate::CLIMATE_MODE_HEAT;
        break;
      case COMMAND_COOL:
      case COMMAND_ON_COOL:
      default:
        this->mode = climate::CLIMATE_MODE_COOL;
        break;
    // Get fan speed
      if (this->mode == climate::CLIMATE_MODE_COOL || this->mode == climate::CLIMATE_MODE_DRY ||
               this->mode == climate::CLIMATE_MODE_FAN_ONLY || this->mode == climate::CLIMATE_MODE_HEAT ||
      if ((remote_state & FAN_MASK) == FAN_AUTO) {
        this->fan_mode = climate::CLIMATE_FAN_AUTO;
      } else if ((remote_state & FAN_MASK) == FAN_MIN) {
        this->fan_mode = climate::CLIMATE_FAN_LOW;
      } else if ((remote_state & FAN_MASK) == FAN_MED) {
        this->fan_mode = climate::CLIMATE_FAN_MEDIUM;
      } else if ((remote_state & FAN_MASK) == FAN_MAX) {
        this->fan_mode = climate::CLIMATE_FAN_HIGH;
    // Get temperature
      this->target_temperature = ((remote_state & TEMP_MASK) >> TEMP_SHIFT) + 15;
  return true;
void LgIrClimate::transmit_(uint32_t value) {
  this->calc_checksum_(value);
  ESP_LOGD(TAG, "Sending climate_lg_ir code: 0x%02" PRIX32, value);
  auto transmit = this->transmitter_->transmit();
  auto *data = transmit.get_data();
  data->set_carrier_frequency(38000);
  data->reserve(2 + BITS * 2u);
  data->item(this->header_high_, this->header_low_);
  for (uint32_t mask = 1UL << (BITS - 1); mask != 0; mask >>= 1) {
    if (value & mask) {
      data->item(this->bit_high_, this->bit_one_low_);
    } else {
      data->item(this->bit_high_, this->bit_zero_low_);
  data->mark(this->bit_high_);
  transmit.perform();
void LgIrClimate::calc_checksum_(uint32_t &value) {
  uint32_t mask = 0xF;
  uint32_t sum = 0;
  for (uint8_t i = 1; i < 8; i++) {
    sum += (value & (mask << (i * 4))) >> (i * 4);
  value |= (sum & mask);
}  // namespace climate_ir_lg
}  // namespace esphome
The .yaml file (replace values where necessary with your own):
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
wifi:
  ssid: "xxxxxxxxxxxxx"
  password: "xxxxxxxxxxxx"
  manual_ip:
    static_ip: 192.168.x.x
    gateway: 192.168.x.1
  ap:
    password: "12345678"
captive_portal:
ota:
  platform: esphome
  password: ""
api:
  encryption:
    key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
logger:
  level: DEBUG
remote_transmitter:
  pin: GPIO2
remote_receiver:
  pin:
    number: GPIO13
    mode: INPUT
    inverted: true
  dump:
    - raw
    - lg
  buffer_size: 2kb
  idle: 25ms
  tolerance: 50%
climate:
    header_high: 3350us
    header_low: 9850us
    bit_high: 527us
    bit_one_low: 1546us
    bit_zero_low: 530us
    name: "LG Bed Room"
    visual:
      min_temperature: 15
      max_temperature: 30
      temperature_step: 1
button:
    name: "Send Power kwht"
    on_press:
      - remote_transmitter.transmit_raw:
          code: [3238, -9954, 407, -1650, 446, -619, 409, -626, 408, -626, 408, -1668, 407, -627, 597, -605, 406, -626, 409, -1659, 409, -1675, 409, -640, 409, -626, 408, -626, 407, -627, 407, -629, 406, -641, 409, -626, 407, -1660, 408, -626, 409, -626, 407, -626, 409, -1659, 650, -1634, 407, -627, 407, -642, 408, -1668, 408, -1660, 408, -633, 408]
          carrier_frequency: 38000Hz
    name: "Send Self Diagnosis"
    on_press:
          code: [3292, -9890, 401, -1687, 402, -640, 401, -633, 402, -632, 402, -1666, 403, -647, 401, -633, 402, -640, 400, -1676, 401, -1674, 402, -640, 402, -632, 402, -633, 400, -633, 401, -641, 401, -641, 400, -1668, 402, -1674, 400, -633, 402, -633, 401, -1674, 401, -1668, 401, -1682, 401, -632, 403, -632, 401, -1675, 401, -1675, 402, -621, 442]
    name: "Send Swing On"
    on_press:
          code: [3194, -9848, 547, -1547, 527, -507, 527, -507, 527, -506, 528, -1548, 526, -516, 527, -516, 526, -516, 526, -507, 527, -507, 527, -507, 526, -1550, 525, -517, 526, -508, 524, -1558, 527, -1566, 524, -526, 525, -525, 525, -508, 526, -1550, 527, -507, 526, -1542, 525, -509, 526, -508, 526, -1543, 525, -516, 526, -515, 526, -1543, 526]
    name: "Send Swing Off"
    on_press:
          code: [3186, -9837, 554, -1543, 526, -516, 556, -495, 557, -491, 526, -1550, 526, -509, 526, -508, 526, -508, 526, -516, 531, -518, 526, -516, 532, -1550, 526, -517, 525, -509, 526, -1558, 525, -1551, 526, -516, 526, -507, 526, -508, 526, -508, 526, -1551, 526, -516, 530, -520, 526, -1547, 528, -1541, 526, -1542, 526, -508, 527, -1549, 527]
Hello, would you mind to test my PR?
It should resolve issues that you’ve experienced.
thanks, it work for AC LG Multi, remote AKB74955614
Hi @ireun!
Sorry for the incredibly late reply — I’ve been away from this “vibe-coding” project for a while, but I finally got around to testing your updates from PR #10875.
I’ve just updated my ESP32 modules and switched from my old custom C++ hacks to using your PR branch as an external component. After enabling alternative_mode: true in my YAML, I can confirm that everything I was struggling with for years now works perfectly “out of the box”!
Here are the highlights from my tests with the AKB74955603 remote:
No more 15°C anomalies: Pressing the swing or light buttons on the physical remote no longer resets the Home Assistant temperature to 15-16°C. The “system” commands are now correctly ignored by the decoder.
Swing Mode Sync: When I activate “Swing” on the remote, Home Assistant now correctly picks up the state as CLIMATE_SWING_VERTICAL.
Echo/Garbage handling: The issues with commands like 0x10000 causing the UI to flip back and forth are gone.
Thank you so much for your hard work on this refactor.
If you are a long-time user of the climate_ir_lg integration and you’ve recently decided to update your ESPHome after a long period (e.g., a few years), you might encounter an issue where your IR receiver stops working completely after a hard reboot (power cycle).
The symptoms:
  • Everything works fine OTA (soft reboot), but after unplugging and replugging the device, the IR receiver becomes unresponsive.
  • The transmitter still works, and the ESP32 connects to Home Assistant perfectly.
  • No IR codes appear in the logs at all, even when pointing a remote directly at the receiver.
The cause: This seems to be related to the evolution of the Arduino framework and ESPHome core over the last few years. Older versions were more permissive with GPIO modes, but newer versions require explicit definition for pin behavior. If your remote_receiver pin is set to mode: INPUT, it may no longer work because the pin is “floating” without a pull-up resistor.
The solution: Simply update your remote_receiver configuration in your YAML file to use INPUT_PULLUP.
Example:
remote_receiver:
  pin:
    number: GPIO13 # Use your specific pin number here
    mode: INPUT_PULLUP # <--- Change INPUT to INPUT_PULLUP
  inverted: true
However, after more extensive testing, I’ve noticed a small but persistent state synchronization issue when using the physical IR remote. Here is how it looks from a user’s perspective:
Turn OFF the AC using the original physical remote.
Home Assistant (HA) correctly updates its status to “Off” (the decoder works fine here).
Now, try to turn the AC ON via the HA Climate card (e.g., by switching to “Cool”).
The problem: The HA interface shows the mode as “Cooling,” but the physical unit remains off and doesn’t beep or react.
The workaround: To get it working again, I have to set the HA state to “Cool” (AC ignores it), then press “Off” in HA (now the AC beeps!), and only after that will it respond to any other mode changes from the UI.
Technical assumption: It seems that when the decoder (on_receive) captures an “Off” command, it updates the climate state but fails to sync the internal mode_before_ variable.
Because of this, the next command sent from HA is treated as a “mode change” (e.g., COMMAND_COOL) instead of a “Power On” command (COMMAND_ON_COOL).
Since the AC is physically off, it ignores simple mode changes and expects the specific power-on bits.
Adding this->mode_before_ = this->mode; inside the on_receive method before publishing the state should fix this desync. Could you please check if this makes sense for your implementation?
The Fix:
Simply updating mode_before_ at the end of on_receive() in climate_ir_lg.cpp completely resolves the issue:
// ... end of on_receive() switch/case ...
  this->mode_before_ = this->mode; // <-- Add this line
  return true;
Could you please add this one-liner? It fixes a long-standing synchronization issue for LG IR users. Thanks!
