Climate IR with panasonic_ckp not working
Hi.
I’m wondering if somebody managed to make the climate ir work with heatpumpir platform using the panasonic_ckp protocol. I have a Panasonic a/c with the A75C2295 remote control (clearly supported by heatpumpir library). My problem is that the a/c is only doing a ‘beep’ twice when esphome sends the command, and seems like it’s sending two commands (because it’s beeping twice). I’m running esphome on the YTF IR Bridge, and it works perfectly with the panasonic_jke platform on the a/c unit in another room (controlled by the same device). Looks like the library is not sending the right IR code.
Here is my config:
climate:
  - platform: heatpumpir
    protocol: panasonic_ckp
    horizontal_default: auto
    vertical_default: auto
    min_temperature: 16.0
    max_temperature: 30.0
    name: "Living Room AC"
    protocol: panasonic_jke
Can somebody confirm that it is working?
Regards.
