Climate Local Tuya configuration
So my local tuya recognized my mobile airconditioning. Yeey! But what do I fill in the configuration properties?
Nobody here that can help me??
I’m just trying to do the same thing.
Power: 1 (value: true)
Target Temp: 2 (value: 22)
Actual Temp: 3 (value: 24)
Mode: 4 (value: cold)
Fan: 5 (value: low)
Sleep: 103 (value: False)
Oscillation: 110 (value: False)
I’m using trial and error to getup the right settings.
I’ve found that setting all the steps to 0.1 makes the temp (in C) display correctly.
I’m still seeing if I can change the mode (but that’s not critical as it’s so noisy I don’t think I would use is just for the fan). I also haven’t been able to change the fan speed, but still playing around with the options.
Ok so temps are working
But I dont have the other values
I found going to set it up a few times with different modes set helped me figure out what the codes mapped to.
2&3 are the most useful, as they are the target temp and actual temp.
My backup option is to figure out an esp with IR control to do the secondary controls, but hopefully I can do to through localtuya.
