Climate negative min_temp value
I can’t use an negative value for my panasonic heat pump. Is it possible to use an negative value for climates?
Background info is, that the heat pump has a configured target temperature, with the control (-5 to 5) you can change this temperature by an offset.
thanks for any info.
Not a feature request.
