Hi all, I have an Aidoo Z‑Wave Plus module to control my Daikin Sky Air air conditioning units. I was able to include the module without issues and apart from the issue I’ll mention below, they have been working well.
The AC units have 6 operation modes: heat, cool, fan, dry, auto (heat_cool), and off. However, for some reason, the ‘fan’ and ‘dry’ operation modes are not properly reported in Home Assistant as ‘hvac_modes’, but as ‘preset_modes’ instead, and this causes issues with the frontend cards as they are not shown, and also weird behaviors when I change the operation mode from the physical wall controller.
These are the attributes I can see from the Development > States page:
hvac_modes:
- 'off'
- heat
- cool
- heat_cool
min_temp: 7
max_temp: 35
fan_modes:
- Low
- High
- Auto medium
- Medium
preset_modes:
- none
- Fan
- Dry
current_temperature: 26.9
temperature: 23
target_temp_high: null
target_temp_low: null
fan_mode: Medium
preset_mode: none
icon: mdi:snowflake
friendly_name: Upstairs Air Conditioner
supported_features: 27
I also re-interviewed the Z-Wave node and captured the following logs:
2023-06-28T12:40:51.013Z CNTRLR [Node 011] Interviewing Thermostat Mode...
2023-06-28T12:40:51.013Z CNTRLR » [Node 011] querying supported thermostat modes...
2023-06-28T12:40:51.022Z DRIVER » [Node 011] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 76
└─[ThermostatModeCCSupportedGet]
2023-06-28T12:40:51.030Z DRIVER « [RES] [SendData]
was sent: true
2023-06-28T12:40:51.046Z DRIVER « [REQ] [SendData]
callback id: 76
transmit status: OK
2023-06-28T12:40:51.060Z DRIVER « [Node 011] [REQ] [ApplicationCommand]
└─[ThermostatModeCCSupportedReport]
supported modes:
· Off
· Heat
· Cool
· Fan
· Dry
· Auto changeover
2023-06-28T12:40:51.066Z CNTRLR « [Node 011] received supported thermostat modes:
· Off
· Heat
· Cool
· Fan
· Dry
· Auto changeover
The node seems to be reporting the modes correctly…
Does anybody have any idea why ‘dry’ and ‘fan’ are configured as ‘preset_modes’ instead of ‘hvac_modes’? Happy to share more details if needed.
Thank you!
