Hello Community,
I have a ESP controller which control my sauna using climate with pid and ac dimmer for a smooth control.
For a safety reason I would like to add a power contactor to cut off the 230 Vac line.
The idea is to turn the contactor once the climate is in mode “HEAT” and turn off when the climate is “OFF”.
I can not figure out how to do so. I’m can imagine something with lambda, but can not figure out where to put it.
Would you have iny suggestions?
- platform: dallas
name: "Sauna temperature"
address: 0x1E00000001BF7128
output:
- platform: ac_dimmer
max_power: 0.8
min_power: 0.2
gate_pin: GPIO32
zero_cross_pin:
number: GPIO33
mode:
input: true
inverted: yes
switch:
- platform: gpio
pin: GPIO21
climate:
- platform: pid
name: "PID Sauna Controller"
visual:
min_temperature: 40 °C
max_temperature: 90 °C
temperature_step: 1 °C
sensor: sauna_temperature_sensor
default_target_temperature: 70°C
heat_output: dimmer1
control_parameters:
kp: 1.44
ki: 13.5
kd: 1.8
