Hello!
I’ve got a CT80 Radio Thermostat which is supported by the component but my version (V2.34T) is not listed on the compatible version of the component.
But since home assistant update the component loads!
On the front end it shows settings, graph window etc.
The operation function (Heat cool etc), fan mode (on, circulate, auto) settings now work from HA to the thermostat!
However, the component says idle (by the graph), has no temperature readings.
The away switch does nothing and I cant change any temperatures on the component.
In logs, I get only two errors.
Logs:
“Home (192.168.1.123) was busy (invalid value returned)”
components/climate/radiotherm.py (ERROR)
“Update of climate.home is taking over 10 seconds”
util/async_.py (WARNING)
This appears to be progress as since before the update nothing appeared front end and there were several component python errors.
Any ideas how to start fault finding?
Best,
Jim
