Im not brilliant at templates, but is it possible to make the set temp of a climate entity = the value of an input_number by using a template???
Id rather not have to use an automation (starting to get a bit crazy the # of automations needed to complete something simple)
pedolsky
(Pedolsky)
October 3, 2023, 10:37am
2
I’m not aware of a possibility to template target_temp
If it’s only a frontend issue, you can use a button or any card that accepts a tap action and call a service.
AllHailJ
(J Gent)
October 3, 2023, 3:25pm
3
If you use the generic thermostat and scheduler you can make the set temp as complicated as you like. Here are screen shots from Lovelace.
The thermostat card and scheduler card
The schedule
http://homeassistant.local:8123/hacs/repository/286186485 is for scheduler install.
You can also schedule anything using the integration. This will help with the multiple automations.
