Climate.set_temperature not working on Honeywell thermostat
Hello and thank you for your help. I am new to HA, so hoping this will be easy. I have a Honeywell Total Connect Comfort thermostat.
I am using the climate.set_temperature service. Here is what it looks like:
service: climate.set_temperature
  entity_id: climate.thermostat
  temperature: 74
  hvac_mode: cool
When I run the action manually, the temperature changes, but the hvac mode does not.
I am running the latest version of HA.
Looking in homeassistant.log, there is nothing obvious.
From the dashboard, I can change the hvac mode from cool to heat and back again.
Any advice?
I am using it like this and it is working flawlessly:
    - service: climate.set_temperature
        temperature: 74
    - service: climate.set_hvac_mode
        hvac_mode: cool
