Climate setup Heater, Fan and Temperature sensor
Been looking around for some example of the climate component with a similar setup to mine but can’t quite find anything.
I have a conservatory with a Temp sensor (MQTT), a heater (MQTT switch) and a 3 speed fan (MQTT).
I have set up generic thermostat for the heater (heat) and fan (cool) but this does not seem to be very user friendly and no control over the speed of the fan.
What I am looking for is the following functionality
  1. Idealy 1 Thermostat to control heating and cooling.
  2. Turning on the function controls heating and cooling with fan speeds dependent on temperature.
    Option for different temperature modes (eg eco, normal, boost)
I assume I am using automatons to control the fan speed. so when cooling is on if the temperature continues to rise then the fan speed is increased.
I did look at the MQTT HVAC component but if this is the right thing to use could do with some examples other than those in the HA documents to get me going.
