Here is a blueprint for setting the temperature of thermostat-entity at specific time to specific temperature. There is a flag to active or deactivate the profile and selection if the profile has to be active at ‘on’ or ‘off’ value of the flag.
You could for example use a “weekend” flag and define two automations with ‘on’ and ‘off’ selection. So you will additionaly get a profile at workdays using one input_boolean or binary_sensor only.
In my case I switch between two different temperature profiles in dependency on the occupation of the room.
If the value of the flag changes, the last temperature of the activated profile is set, as it would be active all the time.
Have fun.
blueprint:
name: Set thermostat temperature at specific time
description: Sets a climate entity to a specifc temperature at a set time everyday. Start with the earliest time of the day i.e. 12:10 AM and end with the latest i.e. 11:00 PM in ascending order. At least one time/temperature pair has to be set.
domain: automation
input:
climate_entity:
description: Climate entity which will get the temperature update
selector:
entity:
domain: climate
active_flag:
description: Input boolean flag as condition for execution
selector:
entity:
domain: input_boolean
active_when:
name: Automation is applied when activity flag is equal to
description: Selection if automation is active at ON or OFF value of the flag
selector:
select:
options:
- 'on'
- 'off'
time_to_set_1:
default:
description: When should the temperature be set
selector:
time: {}
temp_to_set_1:
description: Temperature to set on defined time
default: 19.5
selector:
number:
min: 10.0
max: 30.0
unit_of_measurement: degrees
step: 0.5
mode: slider
time_to_set_2:
default:
selector:
time: {}
temp_to_set_2:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_3:
default:
selector:
time: {}
temp_to_set_3:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_4:
default:
selector:
time: {}
temp_to_set_4:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_5:
default:
selector:
time: {}
temp_to_set_5:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_6:
default:
selector:
time: {}
temp_to_set_6:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_7:
default:
selector:
time: {}
temp_to_set_7:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_8:
default:
selector:
time: {}
temp_to_set_8:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_9:
default:
selector:
time: {}
temp_to_set_9:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
time_to_set_10:
default:
selector:
time: {}
temp_to_set_10:
default: 19.5
selector:
number:
min: 10.0
max: 30.0
step: 0.5
mode: slider
- platform: state
entity_id: !input active_flag
- platform: time
at: !input 'time_to_set_1'
- platform: time
at: !input 'time_to_set_2'
- platform: time
at: !input 'time_to_set_3'
- platform: time
at: !input 'time_to_set_4'
- platform: time
at: !input 'time_to_set_5'
- platform: time
at: !input 'time_to_set_6'
- platform: time
at: !input 'time_to_set_7'
- platform: time
at: !input 'time_to_set_8'
- platform: time
at: !input 'time_to_set_9'
- platform: time
at: !input 'time_to_set_10'
condition:
- condition: state
state: !input 'active_when'
- choose:
- conditions:
- condition: trigger
sequence:
- alias: "Find T to be set"
variables:
T_1: !input temp_to_set_1
T_2: !input temp_to_set_2
T_3: !input temp_to_set_3
T_4: !input temp_to_set_4
T_5: !input temp_to_set_5
T_6: !input temp_to_set_6
T_7: !input temp_to_set_7
T_8: !input temp_to_set_8
T_9: !input temp_to_set_9
T_10: !input temp_to_set_10
time_1: !input time_to_set_1
time_2: !input time_to_set_2
time_3: !input time_to_set_3
time_4: !input time_to_set_4
time_5: !input time_to_set_5
time_6: !input time_to_set_6
time_7: !input time_to_set_7
time_8: !input time_to_set_8
time_9: !input time_to_set_9
time_10: !input time_to_set_10
T: >-
{% set all_values = [[time_10, T_10],[time_9, T_9],[time_8, T_8],[time_7, T_7],[time_6, T_6],[time_5, T_5],[time_4, T_4],[time_3, T_3],[time_2, T_2],[time_1, T_1]] %}
{% set result = namespace(time_curr = strptime( (((as_timestamp(now()) | int ) | timestamp_custom("%H:%M:%S")) | string), "%H:%M:%S"), temp_last = all_values[all_values|length()-1][1]) %}
{# loop from last time of the day, till first set time #}
{% for curr_values in all_values -%}
{% if curr_values[0] and (strptime(curr_values[0], "%H:%M:%S") < result.time_curr) -%}
{# we found previous closest time to now() #}
{# store the temperature #}
{% set result.temp_last = curr_values[1] -%}
{# break the loop #}
{% set result.time_curr = strptime('00:00:00', "%H:%M:%S") -%}
{% endif %}
{% endfor %}
{{ result.temp_last }}
- service: climate.set_temperature
entity_id: !input 'climate_entity'
temperature: "{{ T }}"
- conditions:
sequence:
temperature: !input 'temp_to_set_1'
- conditions:
sequence:
temperature: !input 'temp_to_set_2'
- conditions:
sequence:
temperature: !input 'temp_to_set_3'
- conditions:
sequence:
temperature: !input 'temp_to_set_4'
- conditions:
sequence:
temperature: !input 'temp_to_set_5'
- conditions:
sequence:
temperature: !input 'temp_to_set_6'
- conditions:
sequence:
temperature: !input 'temp_to_set_7'
- conditions:
sequence:
temperature: !input 'temp_to_set_8'
- conditions:
sequence:
temperature: !input 'temp_to_set_9'
- conditions:
sequence:
temperature: !input 'temp_to_set_10'
default: []
mode: queued
Here an example:
