Climate Thermostat - Error Message - Component doesn't inherit from
My Home Assistant System—
Raspberry Pi 4 - 4GB
Home Assistant 2022.10.4
Supervisor 2022.10.0
Operating System 9.0
Frontend 20221010.0 - latest
My Project—
Climate controller’s for my 2 heat pumps. Both are Trane, air-air with electric resistance aux heat. After much research, the ESPHome Thermostat Climate Controller seemed to be the best fit for my goals.
My full error message—
bmp280::BMP280Component doesn’t inherit from sensor::Sensor
My project had been working for a few days with no real problems. Although I would be making some modifications to the code for my personal situation, but only after I tested the basics thoroughly. I was using one of my existing Govee H5075 Hygrometers from Home Assistant for temperature readings. Being a battery powered, bluetooth device, the polling updates were not as often as I would like. I then decided to use a local hardwired sensor for faster response and so the controller would still function, should I lose connectivity to Home Assistant.
This is the working code that I tested for several days with the Govee sensor:
esphome:
esp8266:
  board: esp12e
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "removed"
ota:
  password: "removed"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Hvac-Upstairs Fallback Hotspot"
    password: "removed"
captive_portal:
  - platform: homeassistant
    entity_id: sensor.upstairs_hvac_temperature
    filters:
      - lambda: return (x - 32.0) * 5.0 / 9.0;  # Convert F coming from sensor to C
# Use the blue LED in the device as a status LED, which will blink if there are warnings (slow) or errors (fast)
status_led:
  pin:
    number: GPIO5
    inverted: True
# Four relay outputs, exposed as switches in Home Assistant so I can see their status
switch:
  - platform: gpio
    pin: GPIO16
    name: R-Valve     # Relay 1
  - platform: gpio
    pin: GPIO14
    name: Compressor  # Relay 2
  - platform: gpio
    pin: GPIO12
    name: Aux-Heat    # Relay 3
  - platform: gpio
    pin: GPIO13
    name: Fan         # Relay 4
climate:
  - platform: thermostat
    name: "Upstairs Thermostat"
    default_target_temperature_low: 13.35 C   # 56 F
    default_target_temperature_high: 26.67 C  # 80 F
    visual:
      min_temperature: 10 C  # 50 F
      max_temperature: 30 C  # 86 F
      temperature_step: 0.5  # 0.5 F steps shown in HA thermostat card
    min_cooling_off_time: 300s
    min_cooling_run_time: 300s
    min_heating_off_time: 300s
    min_heating_run_time: 300s
    max_heating_run_time: 60s
    supplemental_heating_delta: 1.7  # 3.0 F
    min_idle_time: 30s
    min_fanning_off_time: 10s
    min_fanning_run_time: 10s
    fan_with_cooling: True
    fan_with_heating: True
    sensor: upstairs_temp
    cool_action:
      - switch.turn_on: r_valve
      - switch.turn_on: compressor
    heat_action:
    supplemental_heating_action:
      - switch.turn_on: aux_heat
    idle_action:
      - switch.turn_off: r_valve
      - switch.turn_off: compressor
      - switch.turn_off: aux_heat
    #  - delay: 30s
      - switch.turn_off: fan
    fan_only_action:
      - switch.turn_on: fan
I had a few BMP280’s on hand so I tested one of those for a few hours using this code. I removed the existing sensor code, the climate component and added the BMP280 code:
captive_portal:
i2c:
  sda: GPIO4
  scl: GPIO2
  scan: False
  - platform: bmp280
    temperature:
      oversampling: 16x
    address: 0x76
    update_interval: 30s
status_led:
  pin:
    number: GPIO5
    inverted: True
switch:
  - platform: gpio
    pin: GPIO16
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO13
    name: Fan         # Relay 4
After testing this for a few hours, I added back the climate component and that is when I got the error message. Both in the ESPHome code editor and in the complier logs.
I substituted both BME280 and BME680 sensors but continued to receive the same error. I then tried using a Dallas sensor and did not receive an error with that code. I don’t have a Dallas sensor on hand to test and I had planned to use a BME280 in my final product. Here is the Dallas code that I used, without error:
dallas:
  - pin: GPIO2
  - platform: dallas
    address: 0xE8011438D052AA28
This is the full code with the BMP280 sensor that resulted in the error code:
esphome:
esp8266:
  board: esp12e
# Enable logging
logger:
api:
  encryption:
    key: "removed"
ota:
  password: "removed"
wifi:
  ap:
    password: "removed"
captive_portal:
i2c:
  sda: GPIO4
  scl: GPIO2
  scan: False
  - platform: bmp280
    temperature:
      oversampling: 16x
    address: 0x76
status_led:
  pin:
    number: GPIO5
    inverted: True
switch:
  - platform: gpio
    pin: GPIO16
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO13
    name: Fan         # Relay 4
climate:
    visual:
    min_idle_time: 30s
    cool_action:
    heat_action:
    idle_action:
    fan_only_action:
I have done quite a bit of researching, and if I did find a solution, I certainly didn’t recognize it… :thinking:
Best regards to all…
I think the id for the bmp280 is at the wrong level. It should (I think) it should be
  - platform: bmp280
    temperature:
      oversampling: 16x
    address: 0x76
You are sooooo correct. I didn’t think you were so I went back to the BMP280 component page and there it was in black n’ white!! I suppose that it didn’t matter when I was only testing the sensor itself as there was nothing else in the code to inherit. Since it was working in that code, I just “assumed” that I had it right. The waters can surely be muddy at times…
With much gratitude!!
