Climate thermostat fan_mode feature not showing
Hi all,
Just trying to understand what I’m doing wrong… need a second pair of eyes.
I’m starting to use HA to control my fujitsu A/C. As this is an optimistic A/C, I had to do some shells scripts and other stuff to get the communication to work between an IR with lirc and HA which is under another server. This is why you’ll see an “SSH” command being done.
The thing is that I didn’t do anything too complexe I believe. I use the climate_template platform (GitHub - jcwillox/hass-template-climate: ❄️Templatable Climate Device for Home Assistant, Supports Running Actions On Service Calls.) which I verified the state of the entity for fan_modes (the value is 9, but it’s 8+1 which should represent hvac_mode + fan_mode, which is what I need).
This is where I believe the frontend part is failing me. I can use the climate-hvac-mode feature on the thermostat card, but I can’t use the climate-fan-modes for some reason. (Features for dashboard cards - Home Assistant)
I do not know what I should be checking for… the python code of the climate_template and the one from javascript frontend seems to tell me it should be working… (https://github.com/jcwillox/hass-template-climate/blob/594041e6d64357676e17b17572d4a9dcf9a63dc7/custom_components/climate_template/climate.py#L212 and https://github.com/home-assistant/frontend/blob/349344161a8c93bdf5fa6ea74a8bea69b5421e3f/src/panels/lovelace/card-features/hui-climate-fan-modes-card-feature.ts#L23).
Yet, I keep getting only the hvac_mode feature and not the fan_mode one… any help to see clearer would be appreciated.
here is my configuration yaml for the climate_template. The rest is just a thermostat card + features which I didn’t touch.
input_number:
  ac_temperature:
    initial: 24
    min: 18
    max: 32
    step: 1
input_select:
  heatpump_fan:
    name: Turn on Fan
    options:
     - auto
     - quiet
     - low
     - medium
     - high
    initial: auto
    icon: mdi:weather-snowy
  heatpump_mode:
    options:
     - auto
     - "off"
     - cool
     - heat
     - dry
     - fan_only
    initial: auto
shell_command:
  ac_on: ssh <REDACTED> irsend SEND_ONCE fujitsu_heat_ac auto-auto-23
  ac_off: ssh <REDACTED> irsend SEND_ONCE fujitsu_heat_ac off
  set_ac_to_slider: 'ssh <REDACTED> irsend SEND_ONCE fujitsu_heat_ac {{states.input_select.heatpump_mode.state|lower}}-{{states.input_select.heatpump_fan.state|lower}}-{{states.input_n
  set_ac_fan: 'ssh <REDACTED> irsend SEND_ONCE fujitsu_heat_ac fan-{{states.input_select.heatpump_fan.state|lower}}-{{states.input_number.ac_temperature.state|int}}'
climate:
  - platform: climate_template
    current_temperature_template: "{{ input_number.ac_temperature }}"
    set_temperature:
      - service: input_number.set_value
         entity_id: input_number.ac_temperature
          value: "{{ temperature }}"
    unique_id: fujitsu
    fan_modes:
     - auto
     - quiet
     - low
     - medium
     - high
    set_hvac_mode:
      - choose:
         # IF off
         - conditions:
             - condition: template
               value_template: "{{ hvac_mode == 'off' }}"
           sequence:
            - service: input_select.select_option
                entity_id: input_select.heatpump_mode
                option: "{{ hvac_mode }}"
            - service: shell_command.ac_off
        default:
         - service: shell_command.set_ac_to_slider
    set_fan_mode:
          entity_id: input_select.heatpump_fan
          option: "{{ fan_mode }}"
