I have a problem with a z-wave thermostat.
I got two entities from the thermostat, heat and eco. If I show one of them in the webif, I can switch the operation mode from heat to eco.
The problem is, the thermostat changes its temperature to eco as expected, but the target temperature is shown from heat mode. If I change the temperature, the target temperature for heat is changed.
Is it possible to combine the two entities for heat and eco in one webif widget?
