Climate Thermostat strange behavior?
Hi there. I found strange behavior of my heating (electric infra panel + Netatmo Indoor sensors).
Here is my config:
- platform: generic_thermostat
  name: Heating Living Room
  heater: switch.elkoep_infra_obyvak
  target_sensor: sensor.netatmo_chalupka_obyvak_temperature
  min_temp: 18
  max_temp: 25
  ac_mode: false
  target_temp: 23
  cold_tolerance: 0.2
  hot_tolerance: 0.2
  heater: switch.elkoep_infra_loznice
  target_sensor: sensor.netatmo_chalupka_loznice_temperature
  min_temp: 18
  max_temp: 25
  ac_mode: false
  target_temp: 19.5
  cold_tolerance: 0.2
  hot_tolerance: 0.2
Here you can see, that temperature is already over set limit, but heating is still ON. Why?
0009
Here you can see graphs - looks like heating is still ON and heats OVER set value and start heating again also after is too cold in the room:
Also here is some strange results. Looks like heating is stopped from time to time even if requested temperature was not set.
Can anyone explain me this?
My HW/SW: RasPi 3B+ with USB SSD, HASOS 3.10, HA 0.105.3
SOLVED - MY mistake! I was reinstalling HA in last 2 days, so I setup different app to maintain heating and I forgot to set it OFF. So on the graphs is FIGHT between two systems and each was using different thermometer settings :frowning:
Maybe it will help someone to be clever than me :smiley:
