Climate.turn_on issue
Everytime i press on climate.turn_on it sends the state 15 to my lg AC . which turns on my ac in a different function because my ac supports 18-30 . degree
I am using ESPhome Climate for LG AC. and I am using custom UI
 however  i found out these attributes from states. i dont know how to modify that default 15 degree temp command to 18 or something else
hvac_modes: off, heat_cool, cool, dry
min_temp: 18
max_temp: 30
target_temp_step: 1
fan_modes: auto, low, medium, high
swing_modes: off, vertical
current_temperature: 0
temperature: 15
fan_mode: low
swing_mode: off
friendly_name: anuronir Living Room AC
supported_features: 41
and the UI code is here
- type: custom:button-card
            entity: climate.anuronir_living_room_ac
            double_tap_action: !include popup/sovrum_klimat.yaml
            template:
              - base
              - icon_climate
              - circle
            variables:
              circle_input: >
                  if (entity) {
                      return entity.state === 'cool'
                          ? Math.round(entity.attributes.temperature).toString()
                          : Math.round(entity.attributes.current_temperature).toString();
              circle_input_unit: "°C"
