Climate - two modbus registers for target temperature
Hello, I would like to ask You, because I have no idea how to do it. I have a heat pump with modbus. I would like to create a climate card but that heat pump has twu registers for tearget temp. One for cooling mode and the next one for heating mode. Do You know how to do it ?
Hi, have you found a solution to your problem? I also have the same problem with ideal clima fan coils.
Hi, i think you can solve it with templating and if it is heat, target_temp_register: 53, if is cold, target_temp_register: 54.
not tried yet but searching something similar.
