Climate unavailable after Core restart
I restarted Core and noticed that my climate entity is missing because it didn’t get a good response when the system was coming back up.
Will the [homeassistant.components.honeywell.climate] or some other component retry to login again after a certain amount of time or is it one and done?
The Honeywell (TCC) servers always seem to be throwing errors now and then. Would be nice if HA tried to recover later on or if I can setup some sort of automation to try and recover it myself. Thanks for any help or advice!
Last log message:
2021-05-14 13:10:43 ERROR (SyncWorker_3) [homeassistant.components.honeywell.climate] Failed to initialize the Honeywell client: Check your configuration (username, password), or maybe you have exceeded the API rate limit?
