Clock-weather-card
Hi everyone,
I recently came across a video on TikTok showcasing an amazing Home Assistant dashboard, and I’ve been inspired to recreate the weather card shown in the clip. Here’s a screenshot from the video:
and this is the video link.
what i’m not able to do is to combining these elements into a single seamless card? even with the icons i’m not able to get the same.
You don’t need to recreate the weather card. What you have to do is to install the HACS integration and then install the custom Clock-Weather-Card dashboard.
Search for “home assistant hacs” and follow the installation instructions.
After you have installed HACS you have a dashboard in the left menu. Use it to find and install the Clock-Weather-Card.
Please read and follow the docs.
i have done this, but i’m not able to add the icons at the butto.
this is my actual progression, but i’m not abel to remove the line rfom between the two.
Did not look at that detail.
But there is some HACS stacked tile front-end component, combined with buttons.
There is a stack-in-card custom dashboard component that might help.
