Clone history_stats without using recorder
The main problem I encounter in history_stats is having to record the entity_id used in the recorder. This constrains should you want to keep
data for a long time to record for many days, bringing a large utlization of resources, with the risk of the db becoming corrupted and losing everything.
With this alternative I tried to replicate a history_stats sensor without using the recorder.
As a first step I create a sensor that increments the time at the time of utlization, based on the last_changed and the state of the entity_id (in the example switch.luce_studio).
template:
- sensor:
- name: "increment_time"
unit_of_measurement: min
icon: mdi:history
state: >-
{%if is_state('switch.luce_studio', 'on') and as_timestamp(states.switch.luce_studio.last_changed) <= as_timestamp(now())%}
{{((as_timestamp(now()) - as_timestamp(states.switch.luce_studio.last_changed))/3600)|round(6)}}
{% else %}
0
{% endif %}
This sensor is successively passed to utility_meter, so that it can track for time customizable by the platform itself (in the example yearly)
utility_meter:
increase_time_year:
source: sensor.increment_time
cycle: yearly
We now convert the sensor to a more readable value.
template:
- sensor:
- name: "time_use_year"
icon: mdi:history
state: >-
{% set hours = states('sensor.increase_time_year') | float(0) %}
{% set minutes = ((hours % 1) * 60) | int(0) %}
{% set hours = (hours - (hours % 1)) | int(0) %}
{% set day = ((hours |int(0) /24))|int(0) %}
{% if day|int(0) >0 %}
{{day}}d {{(hours|int(0))-(day*24)}}h {{minutes}}m
{% elif hours|int(0) >0 %}
{{hours}}h {{minutes}}m
{% else %}
{{minutes}}min
{% endif %}
Finally we have our sensor.time_use_year to use.
Another aspect not to be underestimated is the ability to reset the sensor (which is not possible with history_stats).
script:
reset_time:
sequence:
- service: utility_meter.calibrate
value: "0"
entity_id:
- sensor.increase_time_year
