I want to close one of my blinds for 50% at a specific time. I looked at the documentation and found 2 things: cover.close_cover and cover.set_cover_position. Neither giving the result I want. I guess for the cover.close_cover, it is normal to close it all the way, but when I use the other, nothing happens (not in node red, not in developer tools). I set it up like this:
Does your cover support setting a position? Also you donāt need to hide the entity_id of your cover thatās nothing that someone could use to āhackā your system or similar and I highly suggest changing the entity_id, how can you work with entity_ids with such obscure names?
