I have created an automation to open the garage door when any of the device_tracker are within a certain area of the home. That automation has been pretty successful every now and then it will not open but for the most part works fine.
Now I would like to have HA check to see if all device_trackers are gone from the house then close garage door. Can anybody help me out with this automation.
You could either remove those entities from being tracked or create a new group containing only the entities that you want the trigger to be based off.
Might go without saying but be really careful automating something like a garage door. I know ours weighs a ton, so any automation is out of the question for us until we have some kind of safety feature in place.
One more hurdle. I have a couple of states for device_tracker, home, not_home, work and one other location. How do I get HA to see multiple locations for trigger? Anything but home would be great.
Sorry I was not very specific, I have created the group with the device-trackers I just do not know how to establish how those trackers report either home or not_home. I am using Life360 as the presence detector and not sure how to get HA to see only home or not_home
Iām not familiar with the Life360 component, but most device trackers default to home and away, unless other zones are specified. The not_home state is special in that it returns true if the tracker reports any location other than home even if the actual state reported is away, work, etc.
