I would like my beddroom rf shutter to close at 70% if the temperature of the same bedroom goes above 23º. I use seconds to close and than wait another few seconds to send the “stop” command.
I have this but only works if i trigger it mannualy…
A Numeric State Trigger will trigger at the moment when temperature increases above the threshold value of 23. After crossing the threshold, it will not trigger again until the temperature first decreases below the threshold and then rises above it.
In other words, if the temperature is currently above 23, no matter how much more it increases it will not trigger the automation.
It works when you manually execute the automation because when you do it that way it skips the trigger (and condition) and only executes the action.
