Hi ,
Duckdns and Let’sEncrypt (http challenge) have been setup successfully as per their add-on documentations ’ except the hhtp part in configuration.yaml file for the Duckdns addon).
The HA version is in my signature below.
When testing the remote access from the HA Android application , the following error is displalyed on the HA app :
ERR_SSL_PROTOCOL_ERROR
There are no infirmation in the logs so I took a tcpdum trace to get the message received by Home assistant ( screeshot attached )
Sounds like the protocol used is http and not https as per the trace.
in the HA Android App / Parameters / URL Home Assistant is https://subdomain.duckdns.org:8123
In the 4G router , NAT 8123 <-> 8123 is setup
Please any advice ?
