I have a Fortrezz Zwave water flow meter(product, device info). It reports cumulative water consumption only, but it is nice to have a view of water flow over time. I was able to get this with open zwave, because a sensor was created for the “previousValue”. With the ZwaveJS integration, a sensor is only created for the latest flow value. I do see the other values in the zwaveJS logs:
2021-03-23 14:49:47.261 INFO ZWAVE: Node 4: value updated: 50-0-value-197121 127685.3 => 127685.3
2021-03-23 14:49:47.263 INFO ZWAVE: Node 4: value updated: 50-0-previousValue-197121 127684 => 127685.3
2021-03-23 14:49:47.265 INFO ZWAVE: Node 4: value updated: 50-0-deltaTime-197121 60 => 60
2021-03-23 14:56:46.520 INFO ZWAVE: Node 4: value updated: 50-0-value-197121 127685.3 => 127685.4
2021-03-23 14:56:46.522 INFO ZWAVE: Node 4: value updated: 50-0-previousValue-197121 127685.3 => 127685.3
2021-03-23 14:56:46.524 INFO ZWAVE: Node 4: value updated: 50-0-deltaTime-197121 60 => 419
I’d like to either get delta and previousValue broken out into sensors, or maybe even better, added as attributes onto the value sensor.
I’m using the ZwaveJS2Mqtt add-on version 0.8.1, ZwaveJS2Mqtt version 2.4.1, and zwave-js 6.6.3.
