I’ve installed the NGINX addon and configured with hassio.example.com and letsencrypt certificate to point to my hassio server. This works fine. But when try to add a second domain to point to my qnap nas on a different machine from qnap.example.com, it doesn’t work.
I have created /share/nginx_proxy/qnap.example.com.conf
server {
server_name qnap.example.com;
location / {
proxy_pass http://192.168.1.15;
But when I restart the add-on I get the following error:
[INFO] Running nginx...
2018/12/04 11:22:59 [emerg] 8#8: bind() to 0.0.0.0:80 failed (98: Address in use)
2018/12/04 11:22:59 [emerg] 8#8: still could not bind()
Is there something I’m missing? I’ve read to most of the nginx threads but I couldn’t find any working solution.
