Hi ,
Periodic errors are present in the home-assistant.log :
2020-12-15 04:57:59 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.eur_usd fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 474, in async_device_update
raise exc
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/alpha_vantage/sensor.py", line 212, in update
self.values, _ = self._foreign_exchange.get_currency_exchange_rate(
File "/usr/local/lib/python3.8/site-packages/alpha_vantage/alphavantage.py", line 218, in _format_wrapper
call_response, data_key, meta_data_key = func(
File "/usr/local/lib/python3.8/site-packages/alpha_vantage/alphavantage.py", line 160, in _call_wrapper
return self._handle_api_call(url), data_key, meta_data_key
File "/usr/local/lib/python3.8/site-packages/alpha_vantage/alphavantage.py", line 339, in _handle_api_call
raise ValueError(json_response["Information"])
ValueError: Thank you for using Alpha Vantage! Our standard API call frequency is 5 calls per minute and 500 calls per day. Please visit https://www.alphavantage.co/premium/ if you would like to target a higher API call frequency.
=> Seems to be linked to changes from release 0.115 or 0.116 or a bit earlier as I do not recall exactly.
Is it a know issue or just me ?
Thank you
