Closing the roller shutter when wind speed is high
Hello there,
has anyone already a solution for an autiomation that closes the roller shutter (i hope this is the correct english term) when wind speed is high or forecast is high windspeed.
I have the Netatmo windmeter installed and i have the met.no integration.
First i tried to get the netatmo to tell me the wind speed, but it seems it only tells me the average of the last 10 mins, which i dont think is enough to be sure no damage will occur.
with the met.no i made an automation that sends a telegram message which is triggered like:
trigger: numeric_state
entity_id:
  - weather.forecast_home
attribute: wind_speed
above: 30
But i dont know for which time period this weather.forecast_home is.
Is there something i could do, to accurately close the roller shutter?
And know when the situation is ok to reopen them again?
Has anyone made such an automation?
I am happy if i could get help here.
Greetings
The answer to “But i dont know for which time period this weather.forecast_home is.” is every time you run it (in an automation). The question is how often the Met.no updates its data is another. I’d guess the minutely, though I don’t know what, if anything, you might have to pay for more frequent polling. I tried poking around the Met.no site with Google translate without success in the time I was giving it, but Google may be your friend. You might try to see if OpenWeatherMap has fairly good information for your area. They update every minute or so; you have to be careful how often you poll. I generally find that once an hour is enough; you might want more often. I think the free limit is 1000/day.
Hello there,
But the met.no IS the trigger in my automation. Means i do not run it myself.
I only wanted to know if the trigger triggers for which time.period the forecast is.
i changed it a bit and made an automation that checks daily forecast and doesnt open when its over 30.
thanks for you help
