Clou9 - new way to edit Home Assistant configuration files
Hi all,
after long time searching for the best and easy way to edit my configuration files i came up with Cloud9 wich is
Web based IDE that allows you ato Edit, Upload, Download configuration files, test your python scripts, run bash command and much more.
I wrote an article to help you set this up.
Hope you will find it useful.
sudo apt inatsll git -y
seems like that should be
sudo apt-get install git -y
Other than that, thanks for the writeup!
Both will work :slight_smile:
I have fixd it,
