Cloud - cannot import name 'DEFAULT_CIPHERS' from 'urllib3.util.ssl_'
Forgive me if this is a newbie issue. Everything was working great on my system until today when I get this error (on a reload). Now I cannot access through Nabu Casa (yes I put in a ticket, but thought someone here might know whats wrong).
Logger: homeassistant.components.hassio
Source: components/hassio/init.py:568
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 2:02:16 PM (1 occurrences)
Last logged: 2:02:16 PM
The system cannot restart because the configuration is not valid: Component error: cloud - cannot import name ‘DEFAULT_CIPHERS’ from ‘urllib3.util.ssl_’ (/usr/local/lib/python3.11/site-packages/urllib3/util/ssl_.py)
Invalid config
The following integrations and platforms could not be set up:
Please check your config and logs.
Home Assistant Core
[139648748091408] The system cannot restart because the configuration is not valid: Component error: cloud - cannot import name ‘DEFAULT_CIPHERS’ from ‘urllib3.util.ssl_’ (/usr/local/lib/python3.11/site-packages/urllib3/util/ssl_.py)
2:02:16 PM – (ERROR) Home Assistant WebSocket API
2:02:16 PM – (ERROR) Home Assistant Supervisor
Setup failed for default_config: (DependencyError(…), ‘Could not setup dependencies: cloud, mobile_app’)
1:50:05 PM – (ERROR) setup.py
Unable to set up dependencies of default_config. Setup failed for dependencies: cloud, mobile_app
Setup failed for cloud: Unable to import component: cannot import name ‘DEFAULT_CIPHERS’ from ‘urllib3.util.ssl_’ (/usr/local/lib/python3.11/site-packages/urllib3/util/ssl_.py)
1:50:04 PM – (ERROR) components/cloud/init.py - message first occurred at 1:49:45 PM and shows up 2 times
