### The problem
Cant access HA remotely due to defauly_ciphers error, see log:
Logger: homeassistant.setup
Source: components/cloud/__init__.py:9
First occurred: 08:50:41 (3 occurrences)
Last logged: 08:50:54
Setup failed for cloud: Unable to import component: cannot import name 'DEFAULT_CIPHERS' from 'urllib3.util.ssl_' (/usr/local/lib/python3.11/site-packages/urllib3/util/ssl_.py)
Setup failed for netatmo: Unable to import component: cannot import name 'DEFAULT_CIPHERS' from 'urllib3.util.ssl_' (/usr/local/lib/python3.11/site-packages/urllib3/util/ssl_.py)
Setup failed for mobile_app: Unable to import component: cannot import name 'DEFAULT_CIPHERS' from 'urllib3.util.ssl_' (/usr/local/lib/python3.11/site-packages/urllib3/util/ssl_.py)
File "/usr/src/homeassistant/homeassistant/setup.py", line 215, in _async_setup_component
component = integration.get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 813, in get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.11/importlib/__init__.py", line 126, in import_module
File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/cloud/__init__.py", line 9, in <module>
from hass_nabucasa import Cloud
File "/usr/local/lib/python3.11/site-packages/hass_nabucasa/__init__.py", line 15, in <module>
from .auth import CloudError, CognitoAuth
File "/usr/local/lib/python3.11/site-packages/hass_nabucasa/auth.py", line 11, in <module>
import boto3
File "/usr/local/lib/python3.11/site-packages/boto3/__init__.py", line 16, in <module>
from boto3.session import Session
File "/usr/local/lib/python3.11/site-packages/boto3/session.py", line 17, in <module>
import botocore.session
File "/usr/local/lib/python3.11/site-packages/botocore/session.py", line 29, in <module>
import botocore.credentials
File "/usr/local/lib/python3.11/site-packages/botocore/credentials.py", line 34, in <module>
from botocore.config import Config
File "/usr/local/lib/python3.11/site-packages/botocore/config.py", line 16, in <module>
from botocore.endpoint import DEFAULT_TIMEOUT, MAX_POOL_CONNECTIONS
File "/usr/local/lib/python3.11/site-packages/botocore/endpoint.py", line 22, in <module>
from botocore.awsrequest import create_request_object
File "/usr/local/lib/python3.11/site-packages/botocore/awsrequest.py", line 24, in <module>
import botocore.utils
File "/usr/local/lib/python3.11/site-packages/botocore/utils.py", line 32, in <module>
import botocore.httpsession
File "/usr/local/lib/python3.11/site-packages/botocore/httpsession.py", line 10, in <module>
from urllib3.util.ssl_ import (
ImportError: cannot import name 'DEFAULT_CIPHERS' from 'urllib3.util.ssl_' (/usr/local/lib/python3.11/site-packages/urllib3/util/ssl_.py)
### What version of Home Assistant Core has the issue?
core-2023.7.3
### What was the last working version of Home Assistant Core?
core-2023.7.0
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
_No response_
### Link to integration documentation on our website
_No response_
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
import boto3
### Additional information
_No response_
