I use voice assistants, through Nabu Casa. Since this evening, I have come across a strange issue in Hassio where I consistently see a notification indicating problems with default_config, and cloud. I can no longer see cloud integration in the configuration panel, and cannot control my entities with Alexa. Apart from that, I have not found any problems with Homeassistant. I can control everything locally. I am kind of a newbie in this, and the log I have checked hardly make any sense. Can anybody help?
I run Hassio on RPi
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 426, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 421, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.7/http/client.py", line 1344, in getresponse
response.begin()
File "/usr/local/lib/python3.7/http/client.py", line 306, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.7/http/client.py", line 275, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.7/site-packages/botocore/httpsession.py", line 263, in send
chunked=self._chunked(request.headers),
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 725, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 379, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 734, in reraise
raise value.with_traceback(tb)
chunked=chunked,
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/cloud/__init__.py", line 234, in async_setup
await cloud.start()
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 237, in start
await self.client.logged_in()
File "/usr/src/homeassistant/homeassistant/components/cloud/client.py", line 113, in logged_in
await self.alexa_config.async_enable_proactive_mode()
File "/usr/src/homeassistant/homeassistant/components/alexa/config.py", line 55, in async_enable_proactive_mode
await self._unsub_proactive_report
File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 26, in async_enable_proactive_mode
await smart_home_config.async_get_access_token()
File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 114, in async_get_access_token
resp = await cloud_api.async_alexa_access_token(self._cloud)
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/cloud_api.py", line 16, in check_token
await cloud.auth.async_check_token()
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/auth.py", line 174, in async_check_token
await self._async_renew_access_token()
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/auth.py", line 201, in _async_renew_access_token
await self.cloud.run_executor(cognito.renew_access_token)
File "/usr/local/lib/python3.7/site-packages/pycognito/__init__.py", line 620, in renew_access_token
AuthParameters=auth_params,
File "/usr/local/lib/python3.7/site-packages/botocore/client.py", line 357, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.7/site-packages/botocore/client.py", line 648, in _make_api_call
operation_model, request_dict, request_context)
File "/usr/local/lib/python3.7/site-packages/botocore/client.py", line 667, in _make_request
return self._endpoint.make_request(operation_model, request_dict)
File "/usr/local/lib/python3.7/site-packages/botocore/endpoint.py", line 102, in make_request
return self._send_request(request_dict, operation_model)
File "/usr/local/lib/python3.7/site-packages/botocore/endpoint.py", line 137, in _send_request
success_response, exception):
File "/usr/local/lib/python3.7/site-packages/botocore/endpoint.py", line 231, in _needs_retry
caught_exception=caught_exception, request_dict=request_dict)
File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 356, in emit
return self._emitter.emit(aliased_event_name, **kwargs)
File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 228, in emit
return self._emit(event_name, kwargs)
File "/usr/local/lib/python3.7/site-packages/botocore/hooks.py", line 211, in _emit
response = handler(**kwargs)
File "/usr/local/lib/python3.7/site-packages/botocore/retryhandler.py", line 183, in __call__
if self._checker(attempts, response, caught_exception):
File "/usr/local/lib/python3.7/site-packages/botocore/retryhandler.py", line 251, in __call__
caught_exception)
File "/usr/local/lib/python3.7/site-packages/botocore/retryhandler.py", line 277, in _should_retry
return self._checker(attempt_number, response, caught_exception)
File "/usr/local/lib/python3.7/site-packages/botocore/retryhandler.py", line 317, in __call__
caught_exception)
File "/usr/local/lib/python3.7/site-packages/botocore/retryhandler.py", line 223, in __call__
attempt_number, caught_exception)
File "/usr/local/lib/python3.7/site-packages/botocore/retryhandler.py", line 359, in _check_caught_exception
raise caught_exception
File "/usr/local/lib/python3.7/site-packages/botocore/endpoint.py", line 200, in _do_get_response
http_response = self._send(request)
File "/usr/local/lib/python3.7/site-packages/botocore/endpoint.py", line 244, in _send
return self.http_session.send(request)
File "/usr/local/lib/python3.7/site-packages/botocore/httpsession.py", line 294, in send
endpoint_url=request.url
botocore.exceptions.ConnectionClosedError: Connection was closed before we received a valid response from endpoint URL: "https://cognito-idp.us-east-1.amazonaws.com/".
