After the upgrade, I am no receiving the following error:
The following integrations and platforms could not be set up:
* [cloud](https://www.home-assistant.io/integrations/cloud)
* [default_config](https://www.home-assistant.io/integrations/default_config)
Please check your config.
The log shows:
2020-05-01 22:33:02 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: cloud
2020-05-01 22:33:02 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
But I can’t figure out what dependency it is having an issue with or what to do next.
Any help would be greatly appreciated.
