Getting the following error once i register with Cloud.
Takes ages to restart and eventually produces this error.
The following integrations and platforms could not be set up:
- cloud.binary_sensor
- cloud.stt
- cloud.tts
- default_config
Please check your config and logs.
Section from logs below
2:22:49 PM – (ERROR) Home Assistant Supervisor - message first occurred at 2:22:47 PM and shows up 2 times
Received message for unregistered webhook bd2acb09b3a29e0e376d4dc742b7546ba630300527a0b7e76a28e2d54d10aaa9 from 192.168.1.5
12:46:07 PM – (WARNING) Webhook - message first occurred at 11:32:11 AM and shows up 4 times
Setup failed for default_config: Could not set up all dependencies.
11:32:11 AM – (ERROR) setup.py
Unable to set up dependencies of default_config. Setup failed for dependencies: cloud
Unable to prepare setup for platform cloud.binary_sensor: Unable to set up component.
11:32:11 AM – (ERROR) setup.py - message first occurred at 11:32:11 AM and shows up 3 times
Setup of cloud is taking longer than 300 seconds. Startup will proceed without waiting any longer
Waiting on integrations to complete setup: cloud
11:31:13 AM – (WARNING) bootstrap.py - message first occurred at 11:28:09 AM and shows up 4 times
Error while setting up google_travel_time platform for sensor
11:30:12 AM – (ERROR) Sensor
Setup timed out for stage 1 - moving forward
11:30:09 AM – (WARNING) bootstrap.py
Setup of cloud is taking over 10 seconds.
11:27:21 AM – (WARNING) /usr/local/lib/python3.8/asyncio/events.py
Unexpected error in Remote UI loop
11:27:13 AM – (ERROR) /usr/local/lib/python3.8/site-packages/hass_nabucasa/remote.py
Can’t revoke certificate: urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Certificate is expired
11:27:13 AM – (ERROR) /usr/local/lib/python3.8/site-packages/hass_nabucasa/acme.py
Invalid certificate found: 6dy2cjopmzoo6r3kicq1r1c3uej3t8kl.ui.nabu.casa
11:27:12 AM – (WARNING) /usr/local/lib/python3.8/site-packages/hass_nabucasa/remote.py
