Cloud integration suddenly broke
I noticed I wasn’t able to connect to my HA using the nabu casa link any longer. So I tried using my ddns and that worked. When I check the logs there are all sort of errors referencing python scripts related to nabu casa and other cloud components. I havent made any changes to my config. My current core version is 2021.11.5 and the supervisor is 2021.10.8. These are the errors Im getting. Any ideas where I can start troubleshooting?
2021-12-01 06:26:24 ERROR (MainThread) [homeassistant.setup] Error during setup of component cloud
  File "/usr/src/homeassistant/homeassistant/setup.py", line 254, in _async_setup_component
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/cloud/__init__.py", line 233, in async_setup
    await cloud.initialize()
  File "/usr/local/lib/python3.9/site-packages/hass_nabucasa/__init__.py", line 275, in initialize
    await self._start()
  File "/usr/local/lib/python3.9/site-packages/hass_nabucasa/__init__.py", line 279, in _start
    await self.client.cloud_started()
  File "/usr/src/homeassistant/homeassistant/components/cloud/client.py", line 151, in cloud_started
    await asyncio.gather(*(task(None) for task in tasks))
  File "/usr/src/homeassistant/homeassistant/components/cloud/client.py", line 119, in enable_alexa
    await aconf.async_enable_proactive_mode()
  File "/usr/src/homeassistant/homeassistant/components/alexa/config.py", line 60, in async_enable_proactive_mode
    await self._unsub_proactive_report
  File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 31, in async_enable_proactive_mode
    await smart_home_config.async_get_access_token()
  File "/usr/src/homeassistant/homeassistant/components/cloud/alexa_config.py", line 179, in async_get_access_token
    self._token = body["access_token"]
KeyError: 'access_token'
2021-12-01 06:26:37 ERROR (MainThread) [homeassistant.components.octoprint] Unable to retrieve printer information: Printer offline
2021-12-01 06:26:39 ERROR (MainThread) [homeassistant.components.octoprint.sensor] Printer appears to be offline, skipping temperature sensors
2021-12-01 06:26:39 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/hassio/ingress.py", line 249, in _websocket_forward
    await ws_to.send_bytes(msg.data)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_ws.py", line 307, in send_bytes
    await self._writer.send(data, binary=True, compress=compress)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 685, in send
    await self._send_frame(message, WSMsgType.BINARY, compress)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 650, in _send_frame
    self._write(header + message)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 660, in _write
    raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
Do a forum search. There are a lot of reports of issues with Nabu Casa right now.
I did. Lots of searching. But only found old config issues, docker issues, version issues etc… But I may have been searching before people started to post about this issue. But thanks for the info. Good to know. Someone else shared my post on someone else’s post asking the same thing.
