Cloud Nabu Casa failes to start on Hassio
Hi there, hope someone can help me out here. I’m a newbie, first post (4 days since installing hassio on a Pi4). I want remote control from outside my network. Tried with DuckDNS untill I found out that it just won’t work with 4G router, because T-Mobile uses CGNAT.
So got Nabu Casa which should work over CGNAT… and it did… for 1 day. Now I suddenly couldn’t connect anymore with my phone, unless connected to the Wifi. Notifications keep magically still working btw. Restart takes for ages, because “Setup failes for dependecies: cloud”. Because it fails to load it won’t even show up anymore in configuration.
Tried to replace default_config in configuration.yaml and replace it manually with the default set of integrations without cloud. But since I think don’t know excactly what I’m doing… I was unable to get in from the browser. So edited back the configuration.yaml via the samba network and rebooted via ssh. Somebody knows how to get this Nabu Casa working again? :innocent:
Setup failed for dependencies: cloud
Logger: hass_nabucasa.iot
Source: /usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py:112
First occurred: 3:16:22 PM (9 occurrences)
Last logged: 4:07:31 PM
Unexpected error
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
    six.raise_from(e, None)
  File "<string>", line 3, in raise_from
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
    response.begin()
  File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.8/http/client.py", line 276, in _read_status
    raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
  File "/usr/local/lib/python3.8/site-packages/botocore/httpsession.py", line 254, in send
    urllib_response = conn.urlopen(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 506, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 734, in reraise
    raise value.with_traceback(tb)
    response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
  File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py", line 108, in connect
    await self._handle_connection()
  File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py", line 147, in _handle_connection
    await self.cloud.auth.async_check_token()
  File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/auth.py", line 172, in async_check_token
    await self._async_renew_access_token()
  File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/auth.py", line 199, in _async_renew_access_token
    await self.cloud.run_executor(cognito.renew_access_token)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.8/site-packages/pycognito/__init__.py", line 620, in renew_access_token
    refresh_response = self.client.initiate_auth(
  File "/usr/local/lib/python3.8/site-packages/botocore/client.py", line 357, in _api_call
    return self._make_api_call(operation_name, kwargs)
  File "/usr/local/lib/python3.8/site-packages/botocore/client.py", line 647, in _make_api_call
    http, parsed_response = self._make_request(
  File "/usr/local/lib/python3.8/site-packages/botocore/client.py", line 667, in _make_request
    return self._endpoint.make_request(operation_model, request_dict)
  File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 102, in make_request
    return self._send_request(request_dict, operation_model)
  File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 136, in _send_request
    while self._needs_retry(attempts, operation_model, request_dict,
  File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 228, in _needs_retry
    responses = self._event_emitter.emit(
  File "/usr/local/lib/python3.8/site-packages/botocore/hooks.py", line 356, in emit
    return self._emitter.emit(aliased_event_name, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/botocore/hooks.py", line 228, in emit
    return self._emit(event_name, kwargs)
  File "/usr/local/lib/python3.8/site-packages/botocore/hooks.py", line 211, in _emit
    response = handler(**kwargs)
  File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 183, in __call__
    if self._checker(attempts, response, caught_exception):
  File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 250, in __call__
    should_retry = self._should_retry(attempt_number, response,
  File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 277, in _should_retry
    return self._checker(attempt_number, response, caught_exception)
  File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 316, in __call__
    checker_response = checker(attempt_number, response,
  File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 222, in __call__
    return self._check_caught_exception(
  File "/usr/local/lib/python3.8/site-packages/botocore/retryhandler.py", line 359, in _check_caught_exception
    raise caught_exception
  File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 200, in _do_get_response
    http_response = self._send(request)
  File "/usr/local/lib/python3.8/site-packages/botocore/endpoint.py", line 244, in _send
    return self.http_session.send(request)
  File "/usr/local/lib/python3.8/site-packages/botocore/httpsession.py", line 291, in send
    raise ConnectionClosedError(
botocore.exceptions.ConnectionClosedError: Connection was closed before we received a valid response from endpoint URL: "https://cognito-idp.us-east-1.amazonaws.com/".
Okok a restart of the router fixed the problem :see_no_evil: :partying_face:
Now find out why the router does this to me :cowboy_hat_face:
