When using the UI to select which voice you want, you can preview the voice and use your own message to do so.
A nice feature of this, is the last message you used is preserved.
However an AWFUL feature of this is that the responses seem to be cached and the cache key does not include the voice id, so if you change voices and don’t change the message, you keep hearing the old voice, making it quite the challenge to audition voices.
