I cannot login into my home assistant web service , it always prompts with homeassistant.components.http.ban] Login attempt or request with invalid authentication
I have multiple containers:
- Home-Assistant Core
- Swag (letsencrypt) for reverse-proxy
- others
I’ve been researching similar topic that suggest adding the reverse-proxy host or network in trusted networks sections. Since I did that, i can access my page, but no login.
The traffic goes : Cloudfare subdomain homeassistant.xxxx.com => xxxxx.duckdns.x ==>> swag(letsencrypt) => docker container
I’ve tried adding all Cloudfare ipv4s in trusted networks without success.
I also tried adding this in nginx.conf without success.
server {
location / {
#proxy_pass http://websocket;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection “upgrade”;}
Also tied with 0.0.0.0/0
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.19.0.17 # Add the IP address of the proxy server
- 172.19.0.0/16
- 192.168.1.0/24
- 0.0.0.0/0
ip_ban_enabled: falselogin_attempts_threshold: 10
