I have the Cloudflare APP installed in HA and the URL and application set in Cloudflar Zero Trust. All of it is working properly. My old policy used email token authentication, which was a major PITA as it needs to be renewed every 30 days.
So I’m trying to set up a client certificate for my domain and apps in Cloudflare for the HA app, but running into problems.
I followed this guide:
In HA App on Android I enter the URL for Cloudflare APP to my HA and I choose the certificate I created and installed. But I get the error:
Unable to connect to Home Assistant.
The remote site requires a client certificate. Please install the required credential on your phone and try again.
Additional attempts to connect result in a “Error Code: 400”
I know my certificate is valid because if I use Chrome on android, it also prompts for the client certificate, which I select, and then it connects successfully.
So I found this page on Cloudflare which says I need to install the Cloudflare CA certificate (under " Setting up mTLS with Cloudflare and Android"):
That did not help any at all.
So, I’m stuck. Anyone got this working or have ideas what to check?
Thanks!
It works without trying mTLS, and I have the forwarded proxie set up in configuration.yaml.
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24 # You may also provide the subnet mask
There are no errors in the HA log relating to cloudflare, proxies. And no errors in the Cloudflare Add-on. And it accepts the certificate and connects properly with Chrome on the same Android phone.
Ok. Just banging my head on the desk all day, so I finally gave up and:
Uninstalled/Reinstalled the HA Android APP
Uninstalled/Reinstalled the CloudFlare Add-On in Home Assistant
Deleted the previously configured Applications in Cloudflare Zero Trust
And started over from scratch using the instructions from kcorg.org (listed above)
And It works!!! OMG!!!
The ONLY Issue I ran into is that I have 2 Home Assistant Servers running at two locations, so when I set up the Cloudflare Add-On in the 2nd instance, it died with
failed to create tunnel: Create Tunnel API call failed: tunnel with name already exists
This is because the tunnel name defaults to Homeassistant, which already existed from the 1st HA server. So under “Show unused optional configuration options” you can specify a different tunnel name than the default.
So, when it doubt, wipe it out. Just bite the bullet and start over from scratch.
I had the same problem and was able to fix it by just deleting all the Home Assistant app’s data (which is equivalent to uninstalling and reinstalling the app).
