CloudFlare config
Making the switch from DuckDNS to CloudFlare and during my initial CloudFlare setup I left the http settings for SSL cert and key. Everything started up fine, can access HA with the new domain through CloudFlare.
I went to disable DuckDNS and when I removed the SSL settings from my config, CloudFlare stopped working with this error:
ERR Request failed error=“Unable to reach the origin service. The service may be down or it may not be responding to traffic from cloudflared: dial tcp 172.30.32.1:8123: connect: connection refused”
If I add the http SSL settings back to config everything seems to work again. I don’t believe I should need those SSL settings with CloudFlare.
Any suggestions?
I have the same issue.
Did you find the right way to do it ?
For now I just put back the configuration file with the ssl information
See this thread on Reddit https://www.reddit.com/r/homeassistant/s/OVV3uOo7BG
