Hi all, recently added Cloudflare so I access HA remotely. It works fine 80% of the time. However every evening I get an Argo Tunnel error, even when I’m entering my local address. Is there a way to access my local address when I’m at home, rather than the tunnel. Or some way to disable it temporarily so I can get access to.my system.!
The HA app allows local ip and remote IP setip and will use local if available
You should be able to access HA using the local IP and port over http
That’s the problem, it gives the same error message
If you get the same error for local and remote connections it’s unlikely to be a cloudflare problem.
