Cloudflare fatal
Bonjour a tous,
Cloudflare fonctionnait et patatra la mise a jour aujourd’hui et une erreur
Je ne sais pas quoi faire
Merci de vos idées
 Add-on: Cloudflared
 Use a Cloudflare Tunnel to remotely connect to Home Assistant without opening any ports
 Add-on version: 4.2.8
 You are running the latest version of this add-on.
 System: Home Assistant OS 11.0  (amd64 / qemux86-64)
 Home Assistant Core: 2023.10.3
 Home Assistant Supervisor: 2023.10.0
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[20:44:25] INFO: Checking add-on config...
[20:44:25] FATAL: 'fxxxxx.info' is not a valid hostname. Please make sure not to include the protocol (e.g. 'https://') nor the port (e.g. ':8123') and only use lowercase characters in the 'external_hostname'.
s6-rc: warning: unable to start service init-cloudflared-config: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
Same here after I ran an update
same here.
I glad to have other VPN, because i cant login to HA :(((((
Same here. Fatal Error hostname is not valid although I changed nothing in the configuration.
Had to Restore the backup now it´s running again. I deactivated the automatic updates for this addon and will skip this version.
Dont update! Otherwise restore to previous version, login local
Same here 4.2.8 breaks my HA CF .
Restored back to working .
Re ran CF update … broken .
Suggest skip 4.2.8
+1
I’m traveling and stuck now
same here, whats the best way to down grade ?
thanks!
ok just restored back to 4.2.7 and im back online :slight_smile:
Version 4.2.9 is just released and fixes the issue introduced in 4.2.8.
Sorry for having post in french :wink: anyway you managed to solve the issue thanks
