Cloudflare Issue from one day onto the other
Dear All,
I had Cloudflare tunnel running now for years.
Now suddently I see a “403: Forbidden” in my browser when accessing my home domain (homebuschac.de).
It is independent of the browser.
I restarted my Laptop and HA and got a message from HA Supervisor that the Cloudflare service couldn’t be started automatically.
I then started the Cloudflare addon manually and saw in the log file error messages.
I have changed nothing neither on my laptop nor on HA and in Cloudflare web site my domain is still shown as active.
I wondered if this has to do with the windows defender (windows 11) - but again I haven’t changed anything - do I need to do something there?
Can someone tell me what the cause could be and how to repair?
Many thanks,
Rainer
Addition: When I use the browser on my mobile phone I will see the homepage of my HA system - so it must have something to do with my windows .
[12:53:59] INFO: e[32mChecking add-on config...e[0m
[12:54:00] INFO: e[32mChecking for existing certificate...e[0m
[12:54:00] INFO: e[32mExisting certificate founde[0m
[12:54:00] INFO: e[32mChecking for existing tunnel...e[0m
[12:54:00] INFO: e[32mExisting tunnel with ID af337272-3e92-4f2c-b34d-e359c8fc27f3 founde[0m
[12:54:00] INFO: e[32mChecking if existing tunnel matches name given in confige[0m
[12:54:04] INFO: e[32mExisting Cloudflare Tunnel name matches config, proceeding with existing tunnel filee[0m
[12:54:04] INFO: e[32mCreating config file...e[0m
[12:54:05] INFO: e[32mValidating config file...e[0m
Validating rules from /tmp/config.json
OK
[12:54:06] INFO: e[32mCreating DNS entry homebuschac.de...e[0m
2024-11-26T11:54:10Z INF homebuschac.de is already configured to route to your tunnel tunnelID=af337272-3e92-4f2c-b34d-e359c8fc27f3
[12:54:10] INFO: e[32mFinished setting up the Cloudflare Tunnele[0m
[12:54:11] INFO: e[32mConnecting Cloudflare Tunnel...e[0m
2024-11-26T11:54:13Z INF Starting tunnel tunnelID=af337272-3e92-4f2c-b34d-e359c8fc27f3
2024-11-26T11:54:13Z INF Version 2024.11.1 (Checksum 84d1c367b48b91ece8b4f348a0fb0ff964d58840445d2d51ed3bfb92ea75d493)
2024-11-26T11:54:13Z INF GOOS: linux, GOVersion: go1.22.5, GoArch: arm64
2024-11-26T11:54:13Z INF Settings: map[config:/tmp/config.json cred-file:/data/tunnel.json credentials-file:/data/tunnel.json metrics:0.0.0.0:36500 no-autoupdate:true origincert:/data/cert.pem]
2024-11-26T11:54:13Z INF Generated Connector ID: 05edc361-4bef-48dd-ab0a-3c25d1395120
2024-11-26T11:54:13Z INF Initial protocol quic
2024-11-26T11:54:13Z INF ICMP proxy will use 172.30.33.3 as source for IPv4
2024-11-26T11:54:13Z INF ICMP proxy will use ::1 in zone lo as source for IPv6
2024-11-26T11:54:13Z INF Starting metrics server on [::]:36500/metrics
2024-11-26T11:54:14Z INF Registered tunnel connection connIndex=0 connection=8d4ca341-b46e-4908-8532-9ec52f8cf876 event=0 ip=198.41.192.67 location=dus02 protocol=quic
2024-11-26T11:54:14Z INF Registered tunnel connection connIndex=1 connection=5fb881ab-02cd-47bf-8bb3-f129717b2a8c event=0 ip=198.41.200.13 location=fra07 protocol=quic
2024-11-26T11:54:16Z INF Registered tunnel connection connIndex=2 connection=b09a2957-d7ef-42b7-ba45-473bb197ee5e event=0 ip=198.41.192.227 location=dus02 protocol=quic
2024-11-26T11:54:17Z INF Registered tunnel connection connIndex=3 connection=d81a9fff-1249-4fa8-a705-0328faa85afc event=0 ip=198.41.200.23 location=fra06 protocol=quic
The list of errors might be useful to pinpoint the cause.
WallyR - what do you mean?
The log does not show errors. Instead the Cloudflare tunnel is build up and access via a Android device is possible.
Just windows somehow blocks … on firefox, edge or Chrome - always the error “403: Forbidden” in the browser window,
Check if HA banned your IP address in /config/ip_bans.yaml
@starob,
I’ve checked it - no bans
I wonder it is all the same in firefox, chrome and edge …
Sounds like maybe a DNS issue.
Try to run “ipconfig /flushdns” in a command prompt.
Many thanks to all of you. After system restarts several times it suddently worked again.
