I’m trying to use de pallet “node-red-contrib-alexa-remote2-applestrudel”,
but I need configure this in the pallet:
![image](https://community-assets.home-assistant.io/original/4X/6/4/7/6479d4bf658e740d9bcf7a426329ddc1a60e7f4f.png)
I put my ip and port, but the erro:
Error 1003:
Direct IP access not allowed
I tried to find, some topic with Cloudflare and this node-red:
But I didn’t find anything.
if anyone had this problem, Would you help me?
Mikefila
(Mike Fila)
2
Have you followed the directions like remove all other alexa nodes and you are using the node red ip with 1880 as the port
I removed all palletes and try to use 1880, but is already using.
I the cloudflare docs:
Network ports · Cloudflare Fundamentals docs
The 1880 ins`t a port that I can use.
I try the others doors, but everyone I get error 1003
Mikefila
(Mike Fila)
4
You will need to use one of the available https ports for node red. On the addon page → configuration tab you can change the port for node red.
I see videos and configs, I need another port for the connection to the count.
But the problem, it`s cloudflare not allow enter website with ip and much ports.
I would like configure cloudflare, to access my ip:port
or another approach to configure
