Cloudflare Origin through haproxy
I have an issue with using Zanzito with my setup. As a note, this works if I use the OwnTracks app on my device but does not work with Zanzito.
I am using Cloudflare for my DNS with HTTP Proxy (CDN) enabled. The traffic should flow as follows, Cloudflare:443 > haproxy:443 > mosquitto:1883 (non-tls)
The logs in Zanzito aren’t useful because all I see is either “MqttException” or “java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.”
Still having no luck.
