Cloudflare tunnel addon failure
I followed the documentation in Cloudflare addon to install it and it is not working. It appears to be on the app side, i.e. HA. Here is the log:
[22:58:06] INFO: Finished setting up the Cloudflare Tunnel
[22:58:07] INFO: Connecting Cloudflare Tunnel…
[22:58:07] DEBUG: using /tmp/config.json config file
2023-03-29T05:58:07Z INF Starting tunnel tunnelID=783697e3-4d05-4c7d-8e04-cd155d6ec0d5
2023-03-29T05:58:07Z INF Version 2023.3.1
2023-03-29T05:58:07Z INF GOOS: linux, GOVersion: go1.19.3, GoArch: arm64
2023-03-29T05:58:07Z INF Settings: map[config:/tmp/config.json cred-file:/data/tunnel.json credentials-file:/data/tunnel.json loglevel:info metrics:0.0.0.0:36500 no-autoupdate:true origincert:/data/cert.pem]
2023-03-29T05:58:07Z INF Generated Connector ID: 39501f09-fe87-4401-a283-d9506a53ba58
2023-03-29T05:58:07Z INF Initial protocol quic
2023-03-29T05:58:07Z INF ICMP proxy will use 172.30.33.7 as source for IPv4
2023-03-29T05:58:07Z INF ICMP proxy will use :: as source for IPv6
2023-03-29T05:58:07Z INF Starting metrics server on [::]:36500/metrics
2023-03-29T05:58:07Z INF Connection 3a0155eb-e5fc-4ffe-951d-4b7afbb0e136 registered with protocol: quic connIndex=0 ip=198.41.200.193 location=SJC
2023-03-29T05:58:07Z INF Connection a7208e01-fe6a-4dec-beba-20c05416fef6 registered with protocol: quic connIndex=1 ip=198.41.192.67 location=LAX
2023-03-29T05:58:08Z WRN Failed to serve quic connection error=“Application error 0x0” connIndex=2 ip=198.41.200.13
2023-03-29T05:58:08Z WRN Serve tunnel error error=“Application error 0x0” connIndex=2 ip=198.41.200.13
2023-03-29T05:58:08Z INF Retrying connection in up to 2s connIndex=2 ip=198.41.200.13
2023-03-29T05:58:09Z INF Connection 16948a5f-6d3c-48b5-951f-8404c93722e4 registered with protocol: quic connIndex=3 ip=198.41.192.47 location=LAX
2023-03-29T05:58:10Z WRN Connection terminated error=“Application error 0x0” connIndex=2
2023-03-29T05:58:17Z INF Connection 920d24be-9365-4b76-ac3e-7b17ce641668 registered with protocol: quic connIndex=2 ip=198.41.200.13 location=SJC
Any idea? Your help will be gratefully appreciated! Thanks!
James
Hi James,
I’m having the same issue. QUIC is not working (while i have no ports blocked on my firewalls going to the internet) but after a while it will fallback to:
2023-04-13T09:18:58Z INF Connection xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx registered with protocol: http2 connIndex=0 ip=198.41.xxx.xxx location=AMS
But after I try to connect to the domain name i get 400: Bad Request. HTTP and HTTPS have the same effect. I followed a video and did everything the correct way (followed the video a few times now)
The only difference is that i enterd a FQDN as the hostname in the configuration options. I only want this specific FQDN to be tunneled. If i chec the Tunnels in Cloudflare it says Healthy, but i cant login.
Any help would be greatly appreciated.
