Cloudflare Tunnel Configuration
I have (2) domain names for small websites. I created a tunnel to access both of them and they work great.
Now I am trying to use it to access HA. However, I get the following error.
[13:27:11] INFO: Checking add-on config…
[13:27:11] INFO: Checking for existing certificate…
[13:27:11] INFO: Existing certificate found
[13:27:11] INFO: Checking for existing tunnel…
[13:27:11] NOTICE: No tunnel file found
[13:27:11] INFO: Creating new tunnel…
failed to create tunnel: Create Tunnel API call failed: tunnel with name already exists
[13:27:11] FATAL: Failed to create tunnel.
Please check the Cloudflare Zero Trust Dashboard for an existing tunnel with the name GK_Tunnel and delete it:
Visit https://one.dash.cloudflare.com, then click on Access / Tunnels
s6-rc: warning: unable to start service init-cloudflared-config: command exited 1
I can’t or don’t want to delete my tunnel because there are users accessing it.
Any suggestions what to do next?
I tried uninstalling the HA cloudflare add-on and re-installing it.
now it appears to be working. Did NOT delete the Tunnel as the log suggested.
