My setup: Cloudflare (https) → nginx (https) → home-assistant (https)
When accessing my site through cloudflare’s free account I get constant “reconnecting” toaster pop-up messages which causes the page to refresh. This happens ever 30~45 seconds and is very annoying. Under web-developers tools in chrome I see the following happening:
Request URL: wss://hass.example.com/api/websocket
Request Method: GET
Status Code: 521 Origin Down
Immediately following by a successful request:
Request Method: GET
Status Code: 101 Switching Protocols
When I take Cloudflare out of the picture and hit nginx directly I do not see any 521 errors and the user experience is perfect.
For reference my nginx config is as follows:
events {
worker_connections 1024;
# multi_accept on;
}http {
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
include /etc/nginx/mime.types;
default_type application/octet-stream;ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE ssl_prefer_server_ciphers on; access_log /var/log/nginx/access.log; error_log /var/log/nginx/error.log; gzip on; gzip_disable "msie6"; map $http_upgrade $connection_upgrade { default upgrade; '' close; } upstream websocket { ip_hash; server 192.168.2.100:8123; } server { server_name hass.example.com; listen 443 ssl http2; add_header Strict-Transport-Security "max-age=31536000; includeSubdomains"; access_log /var/log/nginx/hass.access.log; error_log /var/log/nginx/hass.error.log; ssl on; ssl_certificate /etc/letsencrypt/live/hass.example.com/fullchain.pem; ssl_certificate_key /etc/letsencrypt/live/hass.example.com/privkey.pem; ssl_protocols TLSv1 TLSv1.1 TLSv1.2; ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4"; ssl_prefer_server_ciphers on; ssl_session_cache shared:SSL:10m; proxy_buffering off; location / { proxy_pass https://websocket; proxy_http_version 1.1; proxy_redirect off; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection $connection_upgrade; proxy_buffering off; proxy_connect_timeout 86400; proxy_read_timeout 86400; proxy_send_timeout 86400; } }
I know other people are using cloudflare and there is even a component for cloudflare users. I’ve searched the forums for this problem but haven’t seen this particular problem described anywhere. I must be doing something wrong. Any help is appreciated.
I should also mention I have disabled Cloudlfare’s Rocket Loader feature as described here: Cloudflare - Issues to be aware of
