Cloudflared won't start since update to 5.0.0
Hi Community,
This morning I updated to Cloudflared 5.0.0, however the add on will now not start. I have tried uninstalling and reinstalling but to no avail.
When attempting to start the add on I see the following in the logs
/usr/bin/bashio: line 18: dirname: command not found
s6-rc: warning: unable to start service base-addon-banner: command exited 127
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
Has anybody out there experienced similar? Or might be able to advise on how I may be able to resolve this and get Cloudflared running again?
Many thanks in advance,
Mickey
It sounds like you should look to the add-on repo for guidance and help, as that is the source of the change and the code owner of the software with the error showing.
Thankyou, I have posted the question on GitHub now.
