Cloudflared, Zero Trust and maybe Warp
I have Cloudflared working for remote access to my Home Assistant, using my own domain.
I use WireGuard to access my home network remotely, and appear as a network device on my local LAN (so I can manage cameras and NAS on my Android when I’m out and about - and so I can map NAS drives as local devices on my laptop when I’m away).
I feel I ought to be able to set up another Cloudflared Tunnel, poss using WARP, to make my remote LAN access even simpler - but I am at the limits of my knowledge.
Can anyone advise whether this is possible and give a few pointers (or better still a comprehensive walk thru!!) as to how this can be done please? Or tell me why I shouldn’t bother… :slight_smile:
… or maybe use the same tunnel with additional config. Any ideas please?
No one? (10)
You can map a network using cloudflared, takes proper config though. You’ll need to read the cloudflare docs and put some work in.
Ah thank you. I’d seen that one and bookmarked it for later so will give it a good read.
I’m thinking if it looks too complex I might leave well alone though!
